tick master where does you pedal grab
just installed tick master. my pedal grabs at the top about half inch from letting off the clutch pedal. is this setup right. where should the pedal engage. do I have it set up right my stock pedal grabbed from just off the floor. with tick it grabs neer the top.
also installing new clutch soon does anyone know the torqe specs for arp flywheel bolts and pressure plate bolts.
thanks
thanks
Flywheel bolts are here: http://arpinstructions.com/instructions/330-2802.pdf
I couldn't find the arp pressure plate instructions.
This isn't the first time I've seen arp's online instructions be different than the ones included with the fastener kit. Very interesting for such a reputable company.
That picture is a little old so they probably just update their torque setting.
Anyways this guy called them a year ago and got 85ft/lbs for flywheel and 45ft/lbs for PP.
https://ls1tech.com/forums/16090712-post2.html
thank for tq specs
my car has stock clutch still. upgrading to monster stage 3 very soon. anyone know where the tick mc sopsosed to grab/ingage top of travel or as soon as it lifts off the floor thanks for help.
