Tick Master installed! Couldnt be happier!
Regular driving was fine.
But hard races and track days were just disappointing. I prob lost about .3 to a half sec at the strip from granny shifting or not revving past 6k.
This is the most necessary mod for a 6speed ever
The reason it is easier to press the pedal downwards is that you have decreased the amount of stroke your master cylinder has. Because of this, you have decreased the amount of fluid you're cylinder is moving. As a result, the effort required to depress the pedal is now lessened.
The reason our master cylinder makes your clutch pedal effort higher is due to the amount of increased fluid volume that it moves due to the increase in bore diameter our master has over the factory master. The longer the stroke(higher the clutch pedal) the more fluid volume that the master cylinder moves. Think of it as an air pump(or in this case a fluid pump). The longer the stroke and larger the bore the more volume it will move.
This is why the pedal is a bit heavier with ours, but the result is lightning fast shifting that could never be accomplished with the factory master AND our LIFETIME WARRANTY that accompanies the product.
How many aftermarket products do you know of that carry a lifetime warranty? Not very many...
Thanks for all the kind words as well guys! Tick Shift FTW!
I can't believe years of frustration where solved with this.
Anyone who reads this thread with a 6speed.
JUST DO IT STOP READING AND JUST GO DO IT.
YOU'RE WELCOME.
