what do i need to change the clutch EVERY last piece and part
Long *** socket extension (as long as you can get), 15mm swivel head socket, pry bar, blue and red lock tite, someone who can bench 150lbs if you don't have a transmission jack (you can steady it on a regular jack, but just in case :-) ).
being that I just did mine here ya go
jack and stands/ramps
15mm to remove y pipe and xmember
7/16 to remove drive shaft
13mm to remove shifter "stick"
13mm and a swivel to remove 8 trans to bell housing bolts
small flat head to remove slave line
10mm to remove slave from trans
15mm to remove 8 bell housing to engine bolts
13mm to remove pressure plate
15 mm to remove flywheel
pilot bearing puller to remove pilot
thanks guys, some good stuff. how hard is it to get that pilot bearing out of there?
bleeding the slave can i not just do it by the book, pumping it up and all . im thinkin about opening the bleeder and try and let the gravity flow some fluid down before it goes back in too. can i get the puller at an auto parts store?
I decided to try and bleed mine the old fashioned way. Got so frustraited that I drove to work (32 miles) to get my mityvac. but hey it works for some. And I have very little patiance.
good luck.
Yeah, they are like $35 from pepboys, cheaper if you have a harbor freight around. As for the pilot bearing, many people need to gut it before the tool will fit. I used 1 arm of a small gear puller on a 2lb slide hammer and it popped right out in one piece.... but hardly reusable.
As for the locktite, the red is stronger than the blue. The cartek install instructions (which are great) suggest red for the flywheel bolts, and blue for the 2 bolts that hold on the slave/throwout.
as far as the mity vac..man its so worth the 30 bucks, you can go to autozone and get it
