can i bleed the master out of the car?
im gonna try and do the drill mod and was wondering any way to bleed the master outside of the car? like if i could open the quick disconnect end to lef fluid out. or do i have to hook it all back up and do it in the car
Buschmans clutch bleed method Check out this page for some ideas on how to bleed the master out of the car.
Yup. Here's how I bleed (works great for me).
Hold pedal in. Crack valve open, then close valve. Pull pedal up. Pump 10-20 times. Repeat - hold pedal in, crack open/close valve, let pedal up, pump. Check the reservoir every 2-3 cracks of the bleeder.
I'm the nut who drilled a hole in his floorboard so that I can bleed it by myself too.
Hole goes right next to the gas pedal.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Senior Member
Hole goes right next to the gas pedal. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
