Clutch pedal stays on the ground
There are lots of reasons it can do that. Has it always done this or did it just recently start to act up? The first thing to do would be to bleed the clutch system and get out all the old fluid and air that may be in the system. If that doesn't help it can be a bad master cylinder, bad slave, air getting into the system somewhere, or it could be your pressure plate if you still have the stock clutch.
Stock clutch, bleed twice ,and i only have a cat delete, slp lid and kn filter so my HP is maybe like 330 ? Idk if this helps but when it gets stuck like that I pump the clutch a bit in neutral and it gets stiff again .
You could test the master cylinder for internal bleed by. Disconnect the hydraulic line where it connects to the slave. Then get in the car and put your foot on the clutch pedal, it should be rock hard. Keep some pressure on the pedal with your foot for a while and if the pedal starts to slowly sink down toward the floor the master could be internally failing.
I'm having problems with mine sticking to the floor at high rpms. I have monster level 4 with tick master. Got kit from tick performance. It only does it at high rpm though. Shifts fine any other time and works like its supposed at lower Rpms. Anybody have any idea what could be the problem. All of it has less than 500 miles.
I just found a thread on how to bleed it properly and I didn't do it like that so it could likely be my problem. Fixing to pull it out and go auto anyway. So I'll make sure whoever gets it knows to do it the right way unlike myself Lol.
