Tick Master Install - Line Won't Go Back into Transmission
Old 02-23-2014, 09:04 AM
bluestreak98's Avatar
LS1Tech 20 Year Member
Default Tick Master Install - Line Won't Go Back into Transmission
I started my Tick Master install yesterday. I bench bled the system before installing it and then got it mounted. Once I started pumping the clutch to bleed the system (there was actually no pedal pressure at all) all of a sudden it was rock hard and I couldn't press the pedal down. The master line came out of the trans and now it wont go in. We opened the bleeder to take some pressure off and the clutch pedal is still hard as a rock.
Now the line wont go back into the trans. Any ideas?
Old 02-23-2014, 09:24 AM
M.BOZZ's Avatar
check inside of the clutch slave fitting at the metal fingers inside, see if damaged. as you may know that if you have a rock hard pedal that its not in correctly
Old 03-10-2014, 10:40 AM
I replaced the metal fingers inside the slave fitting with a new one. My stock fitting will snap right back in. The tick one still will not snap into place.
Anyone have any ideas?
Quick Reply: Tick Master Install - Line Won't Go Back into Transmission
