What Fluid Do Put In You T-56?
Tick Performance says to use any brand of non-synthetic DEX 3 ATF. I asked 2 different people Joey and a customer service rep. when I had my transmission rebuilt by them and was told they use parts store brand DEX 3 in their shop, and the paper work that came with the transmission even specifically said never use Mobil 1 or any other synthetic atf.
^^^id run what this guy does.
The only reason I chose it over the Amsoil ATF is because I am trusting that Dave (head tech/tribologist at Red Line) is speaking the truth when he claims that it actually meets the GL-4 manual trans specs, as far as wear, resistance to shear, and gear/bearing protection goes, just like it says on the bottle.
Many people who know MUCH MUCH more about lubes/gear oils/ATFs/etc. than ANY of the Tremec rebuilders (OR even TREMEC themselves) claim that an ATF can NEVER EVER offer the same level of protection against wear, or shear resistance that a manual trans fluid can, so IF I am going to use one, it is going to be the 'stoutest' one out there!
Besides myself, MANY have had this stuff in their, un-rebuilt, not upgraded to carbon blockers, 'paper' blocker ring T56es right from the first change, for MANY, MANY years, and hundreds of thousands of miles with NO problems whatsoever.
You should be just fine with it in the Lone Star State, especially southern Tejas in the summer, when it is as hot as the
