McLeod or monster?
Let us know if you have any questions.
That said, our LT1-S will hold, and has held, that kind of power in heavier cars and is a hell of a lot cheaper - with our current sale they're starting at less than $1k with a flywheel and hardware.
My personal car weighs over 4k and makes 495 rwhp with our LT1-S, it drives like stock and takes a beating with zero issues.
in fact, when i had problems with my pedal sticking to the floor, i had a local trans shop install the Tick MC, stock slave, a speed bleeder, and the clutch kit all at the same time. well, despite me giving them EXPLICIT instructions (along with the instruction sheet shipped with the clutch kit which details EXACTLY how to properly torque everything), these dolts ended up installing the pressure plate incorrectly...the 6 bolts were all torqued differently, anywhere from barely staying in on their own, to needing a long breaker bar to break them loose. this resulted in the fingers of the pressure plate not aligning correctly and clutch engagement problems. due to reasons i won't go into, i ended up driving it that way for a bit (which caused transmission problems requiring a partial rebuild), and it caused hotspotting on both the flywheel and pressure plate mating surfaces, as well as glazing on the clutch disc itself.
once i got the transmission repaired and reinstalled everything correctly myself because i no longer trust anyone in my shitty town anymore, everything worked great with no slipping, no vibrating, nothing, and still handled anything i could throw at it with no problems whatsoever. i just beat the **** out of it a little once i verified the clutch engagement was setup correctly to knock the glazing off. it drove just as smoothly as it did at stock up until the day i wrecked the car.
i'm looking for a rolling chassis at the moment, and i plan on putting my engine and transmission/clutch in it, and still expect no problems from it when that day comes.
Click Here For Web Specials on Mcleod & Monster
Can a LT1-S be used with a Tick MC?
Awesome!!
