McLeod or monster?
I checked, double checked, triple checked bearing cushion and everything is right on spec. Clutch held great and performed well, I even gained 3/10ths over the stage 2, but I wouldnt be jumping up and down praising material life.
It's very well documented on this forum and many others that you can get quite a bit of life, when everything is healthy, out of our 3. Hell, I personally got over 30k miles out of one. We've pulled them to install twins in customers cars numerous times where, at 34k or so miles they're about half way through the life. And these aren't cars that are babied. My personal car was a 3600+ lbs GTO that I beat the sh*t out of daily and it was a track ***** - and with an IRS car you can't just dump the clutch and go, you ride the hell out of it.
BTW, I replied to your PM just now and pointed out where we responded earlier and you missed it. Let me know what you'd like to do about picking up the replacement disc. Considering this post it sounds as if you don't want to pick one up... either way, just let me know.
No, thats not what I'm saying. The clutch was installed in my full weight 1978 Camaro, 460hp to the tires LS1. I admitted it, I don't baby it. I take it to the track, I race it stop light to stop light. I would expect a clutch with more agressive material to wear faster than a less agressive material. Theres just no way I would ever think you could get five digit miles out of one. Like I said, it held awesome! squeeled a little if you didn't drive it hard.
I will post picstures, show you its a good set-up, the material just wore fast.
I'm even the type of guy that puts it in neutral coming to a stop and waiting for the light. Some people ride the pedal. I'm sure it would go faster if you drove it that way.
Give us a call and we'll go into more detail with you to help make your mind up.
As I said before, you're not the norm - something, not sure what in your conversion setup, was amiss.
