New Transmission Alternative? 300zx Transmission
To bring this thread back from the dead, there is a kit to use the 350Z 6 speed transmission behind an LS based engine.
Looks to be a respectable possibility.
http://collinsadapters.com/index.php...-swap-kit.html
They are a very popular choice in the drifting community due to the cost, availability, and the gearing. The CD009 is the preferred series as the CD001 was known for having notable weak points.
Am I missing something here? When you buy a used t56 how many times does it come with a new aftermarket flywheel? Or nice aftermarket clutch for that matter? You guys arguing cost are adding a clutch and flywheel to the cost of the z32 trans swap, yet not including them in the t56 cost? So just please let me know if I’m missing something, or you’re just biased and trying to find ways to argue that the cost of the t56 is the same. Which CLEARLY it’s not.
Also! There’s those of us that prefer shorter gearing. Of course the ls doesn’t need short gearing, but in my opinion it’s just more fun.
Then there’s the fact that many people, myself included, like to part things together. This is a perfect option for someone who didn’t want to, or can’t drop down $1500 all at once for a transmission.
I did an lq4 swap about 10 years ago in an s14 240sx when almost nothing off the shelf existed for this swap. I’ve wanted to do another one recently, but the t56’s haven’t dropped in price since I did my first swap. I personally love the idea of a z32 trans. This is absolutely the only direction I’ll be looking when it’s time for the next swap.
typical 300zx v8 build with z32 trans, just figured by now there would be an alternative to buying from loj or some other brand the kits in my opinion are over priced. So I guess ill just have to spend the money
I got a kit from Gforce. Haven't installed it yet. It was 600 I think but cheaper than a t56. They are the cheapest kit I've seen so far.
From what I know the LOJ stuff is REAL nice. I haven't unboxed my stuff yet I just knew I wasn't gonna spend the money so I said screw it. The only thing about LOJ is that you can use a TT or NA trans (I think). Everyone else is NA only.
#33
Ill try and take as many pictures as i can this is my first project of any kind, so with that said i dont want to make any promises, but i do have what I think to be essentials to the build and time to do so ....so who knows
#35
im running a CD009 which is a 350Z Transmission and its been a adventure. First i have it in my 240sx with a lm7 and i have the collins adapter kit
the issue im having now is finding a clutch for it since i am making over 600 and it needs a 350z input shaft spline count and a ls1 clutch disk size.
i just pmed monster to see.
#36
#37
#38
In my opinion the z32 trans isnt worth it cause one, the starter becomes a headache when doing headers unless your going truck manifold and going boost. second the cd009 is more common than a z32 trans. you can pick up a brand new cd009 from nissan from 1.7k. just depends what adapter kit you will be using. i have it going to a 350z diff and axle which the gear ration on the diff is 3.3. im pretty happy. lower gear ratio and stronger axles? plus for a plus
#39
#40
I totally disagree. If you have a cd009 to start with then yeah, go for it. But for 1700 bucks I'd go with the t56 all day long. As far as availability, yes they are a bit more common but people want practically t56 money for them. Add the adapter and it's not even in the ballpark. Unless money is no object then I suppose it would be preference. As far as a comparison to the z32 trans and a cd009. Yes the cd009 could up being a more stout transmission but for the money the z32 can't be beat. Just look at the gear ratios too. What's the point of having a sixth gear if its a worse ration than the z32's 5 speed? Take the .79 6th gear with a 3.59 rear (available in the manual 350z, 3.35 on an auto) and a 245-45-17 and its 2550rpm to do 70 on the highway. I'd prefer to not listen to the thing drone the whole time. The starter isn't the end of the world either, it can be worked around. Especially with a turbo setup... and come on, who does an ls swap to NOT have a turbo and make a ton of power. The z32 can be had for next to nothing so for me, it's well worth it. Not to mention an experiment considering there's not a lot of information about the swaps out there.
But hey, it's your money.
I'd prefer to sell my 3.9X LSD disc brake rear end and use a cheap as hell explorer rear axle with 3.27 gears with shorter geared trans. I know in a pinch I can pick up a worthless early 350Z trans and be driving again.
