Help with Diamond Stage II Clutch Install on T56
I got a Diamond Stage II clutch for my LS2 and it came with a spacer plate, but I don't know if I need it. Can I get some guidance on what to do here please?
Also, any additional guidance on clutch setup would be greatly appreciated.
that spacer, I believe, is to be used between slave & tranny "if" your measured stack height (FW, disc & PP installed) is lower than xxx height
contact Diamond for measuring procedure see if this thread helps
https://ls1tech.com/forums/manual-tr...need-shim.html
