Oh damn! Help me determine where this spacer goes.
So I just finished building my trans. Well as I was installing the reverse gear I noticed an extra spacer. It is the same size as the two spacers that are on rp either side of the plastic caged bearing after the reverse gear but it is about half the width. It goes on the mainshaft somewhere but every IPB I have found hasn't helped determine the location. I can't button the trans up now knowing a spacer is missing. Which will most likely end up in a bearing eating itself up. Any ideas?
