Monster stage 2 Question
Not sure about that little jump you are talking about. If you upgraded your cam recently, it could be cam surge?
If you are keeping the stock master and only changing the clutch it will be very close to stock. If you are also installing the tick master, it will change the behavior.
It drives better than stock. The shift point is very consistent. The engagement window is narrower. The bore is over 2x bigger, so you have less than half the normal pedal movement during engagement. Some people see this as "like a light switch" compared to the crappy stock master.
It took me a few days to adjust my driving, but now I love it. It always makes good high rpm shifts, and after 10k miles it still behaves like it did when I installed it.
So it is different than stock, but in a good way, once you get used to it
to get used to how the monster lt1s / tick master combo functioned over
the ls7 clutch / factory set up, but once you get used to it, you'll NEVER
go back to a stock set up.
