Clutch Wont Disengage.. opinions?
So I'm driving my 02 SS home today. Car has 84k miles, stock t56, stock clutch (i think) stock everything transmission wise except a tick MC that has been in there for well over a year. Was on the highway, shifted from 3rd to 4th, pedal felt completely different and won't not engage 4th.
I got it to the side of the road to find the clutch is engaged. I can put it in a gear, clutch pedal pushed down and it won't start but in neutral it starts right up.
I looked into this issue, alot of people say Master Cylinder needs to be bleed, but I've been running it for a year plus without an issue so i don't think its that. Clutch disc? Slave Cylinder? Pilot Bearing?
If you had pedal pressure and now you don't, bleeding is not going to cure this. The only way you have hydraulic pressure and then lose it, is either a leak or a bad master cylinder. The master cylinder is the easiest to replace.
Can you clarify? You can't shift at all currently, but could before?
The pedal has slight pressure to it, feels very spongy. Nothing like it used to. I had to have the car towed home.
Moderator
Received 1,838 Likes
Sorry ill clear it up. My car has been fine since i put the MC in a year ago. Today was coming home from work. Shifted from 3rd to 4th, felt/heard a slight pop, then the car would not engage any gear at all. coasted it to the side of the road. I can put it in a gear with the engine off, but if you try to start it you can tell its still engaged.
There was a thread here not that long ago where someone described something similar, and a finger had broken on the pressure plate, but I wouldn't worry about that until the master and slave check out.
Moderator
then, it's something underneath
