ideas for an in-car "do you need a slave shim" measuring tool
LOL - Have you seen this thread? The instructions that came with my Monster Stage 2 say you should measure.....
If you're really that obsessed with measuring something that shouldnt need measured...and even worse, whilst it is all bolted together in the vehicle...
Get a cheapo USB camera, drill a hole somewhere and just look inside.
But really...anything you could ever want to measure, you can measure with the box/trans apart, with ease.
This comment is not from experience. I have only used/am using a 4l80 for high horsepower but am researching and trying to convince myself to try a T56 next build. Why not get a bellhousing with an inspection window so you can slip in a feeler gauge while someone is depressing the clutch so you can check for disengagement and over extension at the same time? Browell will make one to your specs.
