What clutch is everyone using?
My 02 is a bolt on car making around 350whp at this time. Hope to start building a 370ci out of a 6.0 and hope to make around 500whp with the setup.
I have looked at the Rps Street Twin Full Clutch Kit and I like what I see on paper but would like to see what everyone recommends and uses.
Thanks
James
Now with this last setup I started with a used stage 3 I got from a buddy. And I had ran it for a few thousand miles just street driving and racing. No track outings with it until I got it in this new setup. I was leaving with 3.50 gears and 28's on motor and had to ride the hell out of it to get any kind of 60ft. Started getting lazy on the release. But still shifted great. Then I hit it with 150 shot and it really didn't like it lol. Held up enough to get 110mph trap in the 1/8th tho.
Now I just put in a McLeod RXT. No track outings yet. But is holding just fine on the street on motor. Haven't sprayed it yet. But it has the lightest pedal of any clutch I've ever ran. Engages like the spec 3+ and hardly any chatter. Excited to try it at the track on spray.
Thanks
James
For anything under 550 HP I recommend the following
http://www.coloradospeed.com/flywhee...2-p-38031.html
Anything over. Go with something that been in the LS market for a while and needs no "proving" to anyone
http://www.coloradospeed.com/flywhee...gt-p-7061.html
and for a little more power holding for those nitrous spurts
http://www.coloradospeed.com/flywhee...gt-p-7384.html
On your setup you will want the steel billet flywheel
http://www.coloradospeed.com/flywhee...ls-p-6543.html
And with these setups, the stock MC will work fine. You do not need an adjustable master cylinder.
Anyone, anyone here will tell you the McLeod are tried and proven clutches and you do not have to be a guinea pig to test these, they are not new to the market.
Thank you.
All of our clutches are designed to work with stock hydraulics.
As far as aftermarket masters go, the Tick master is a great unit. Just keep in mind that it will increase the pedal stiffness, and shrink the engagement window.
Give us a shout if you have any questions.(817-750-2000)
