Clutch measurement
Hello all
I've been trying to install my clutch for proper disengagement on my 2002 C5 Z06. I am using a Monster LT1S clutch with a stock slave cylinder.
I am following this thread:
https://ls1tech.com/forums/manual-tr...d-shim-11.html
I have found that my "measurement A" is the same as "measurement B". Therefore I need the opposite of a shim:
A shorter TOB or slave assembly
or
A clutch assembly with lower clutch spring forks.
However neither of these seem possible without modifying my equipment.
Am I doing something wrong? I measured dimension B with the clutch bleeder open.
or
