Old 05-13-2016, 03:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
Anyone regret face plating?
Old 04-25-2016, 01:40 PM
  #41
weedburner's Avatar
Why would you need to wait ?
How many cars have you ever driven with dogs or face plates ?
I run a low drag M4 w/ single iron disc. Even with 800rpm idle, takes a while to stop spinning on it's own. Maybe you've got a lot of internal drag and maybe low moi disc?
My street car has been proshifted or faceplated since 2004, many racecars before that. When i first started proshift/faceplating on the street car, it had 1100rpm idle speed so the clutch took even longer to spin down. That's when i started leaving 1st gear synchro'd. Works very well, i'd never go back to a faceplated 1st for a street car.
Old 04-25-2016, 04:37 PM
  #42
stevieturbo's Avatar
Whilst there are times when yes I get a bang when engaging gear....there are also times I need to engage the clutch slightly because the gear wont engage because the faceplates are face on static because the clutch has totally disengaged.
This does tend to be when colder but either way in no way do they always bang.
Likewise a friends car with a sequential box and triple plate ( non LS ) his is always slick to engage, never bangs. His clutch works great on his car.
I think one of the plates of my twin is ever so slightly warped a little though which is why mine does it sometimes
Old 04-25-2016, 04:42 PM
  #43
Jtm2085's Avatar
Reading all of this makes me think it will take awhile to get use to. Maybe Liberty will send me a driving manual 😂
Old 04-25-2016, 06:34 PM
  #44
If you're expecting the smoothness of a synchro, then yes it will be a huge difference
I'm sure a lot will also depend how the car is put together. Mine is all rose jointed, engine bolted solid, big heavy 2 piece driveshaft etc. So it has everything going against it to be nice and smooth.
But it isnt a daily, so it is perfectly acceptable and when going hard, it goes into gears effortlessly which was what I wanted.
Mine needed new synchros and a couple of gears because the synchro teeth were worn, so just decided **** it I'll get this done instead. Overall cost wasnt much more than if I'd been replacing all the synchro related parts anyway.
Old 04-25-2016, 07:48 PM
  #45
HioSSilver's Avatar
Get you a light clutch along with this fp'd t56. You will thank me later
Old 04-26-2016, 04:22 AM
  #46
No need, my clutch works fine, and is silky smooth to drive with.
Any small lightweight clutch to handle 1k+ will never be as nice in that regard.
Old 04-26-2016, 11:27 AM
  #47
HioSSilver's Avatar
I was advising op
Old 04-26-2016, 12:05 PM
  #48
Jtm2085's Avatar
I was in the same boat. My car isn't a DD either
Old 04-26-2016, 12:06 PM
  #49
Jtm2085's Avatar
Originally Posted by HioSSilver
I was advising op
I won't be getting a nice clutch for a little while unfortunately. When my current one wears out I will most definitely be splurging on a ultra light set up!
Old 05-27-2016, 07:30 PM
  #50
Jtm2085's Avatar
I just drove the car for the first time and man what a difference. I watched all the videos I could but still wasn't sure what to expect. There is absolutely no ***** footing around with shifts for sure. It's as noisy as I expect but the effortless power shifts are worth it.
Old 05-28-2016, 08:17 AM
  #51
HioSSilver's Avatar
Once you get used to it and figure out the rythem it will quiet up a bit.
Then you can work on not using the clutch when your on it. Just breathe the throttle pull the gear and it will be smooth as silk goin through the gears.
Old 05-28-2016, 09:53 AM
  #52
Jtm2085's Avatar
I hope to get some more time in it in the next couple days. Hopefully I can get a video. Clutchless shifting sounds nice!
Old 05-28-2016, 05:24 PM
  #53
64post's Avatar
Got mine done by Liberty, took 3 months to get it back, deleted 5th and 6th altogether, in and runs, does clunk a bit going into gear but will only be used at the strip, haven't gone out yet.
Attached Thumbnails Anyone regret face plating?-20151204_213317_resized.jpg   Anyone regret face plating?-20151210_120941_resized.jpg
Old 05-28-2016, 05:43 PM
  #54
Jtm2085's Avatar
Mine took closer to 6 months unfortunately. Your packaging held up much better than mine as well
Old 05-28-2016, 05:51 PM
  #55
64post's Avatar
As long as you got and it works you'll kind of forget about the 6 months. Now go have fun with it.
Old 05-28-2016, 08:40 PM
  #56
HioSSilver's Avatar
What clutch you running 64?
Old 05-29-2016, 12:35 PM
  #57
LFSADRG's Avatar
'scribed. Please add some updates Jtm2085 after you get more time on the FP trans.
Old 05-29-2016, 05:05 PM
  #58
Jtm2085's Avatar
I will get a video soon. Now I have other issues. I went to replace my coolant temp sensor and it broke off in the head 😩
Old 05-29-2016, 09:49 PM
  #59
blk00ss's Avatar
Junk. I wouldn't have it. I'd take it back.
Old 05-29-2016, 10:01 PM
  #60
Jtm2085's Avatar
Temp sensors are optional any way
Quick Reply: Anyone regret face plating?
