Help T56 noise! Working Video
Please help me diagnose this noise. When clutch is pressed in it doesn't make the sound, when I rev it in neutral it doesn't make the sound. It's only when I'm gliding/lightly accelerating. Trans probably only has 10,000km.
Does the rear use OEM gears or aftermarket? Certain gear ratios tend to make more noise too. What's your ratio?
Andrew
Update: Put it all back together, took it to a guy who is more of an expert then I am. And he was 100% sure it was the diff, hold your head out the window and you'll hear it from the diff. Needless to say I put in a summit order today for some 3.73's and a trutrac.
