Replacement for LS7 clutch?
I want to rebuilt my top-end and I am worried that my current clutch setup will be inadequate. What I have now is a LS7 clutch with Fidanza flywheel and Tick MC; it was installed in March 2009 so I am not sure which MC bore I have, but I'm guessing it was the larger 7/8" due to the order date. In addition, I have a rear main seal leak so I figured I might as well have the replacement clutch ready at the same time as the leak is fixed.
I'm looking for a clutch which has similar manners to what I have now but with greater holding power... not knowing what to expect with the top-end rebuild, I think supporting 600rwhp/600rwtq would provide plenty of overhead. The RPS BC2 is a little (okay, a LOT) more than I'd like to spend, and it's designed for the 3/4" MC bore. The Katech LS9X for F-bodies is a little less expensive and Jason says it will work fine for either MC bore size, but I'm gaining a few pounds over what I have now. The LS9X is more expensive for the F-body since more customizations were needed to make it compatible. Could I buy an expensive clutch, sure... but I would prefer not to get more than I need everything else being equal.
Are there other clutches out there which will give me very long life, ease of use, zero chatter, soft pedal and similar performance? I definitely want a lightweight flywheel option (12-13lbs), but I don't want to drop so much weight that it causes drivability problems.
http://monsterclutches.com/1998-2002...t-fbody-clutch
Also keep in mind the lighter you go with the clutch set-up, the more aggressive it will feel. That's why for street driving we recommend a heavier setup. If you are going to do some autocross or HPDE events, the LT1-S with our Lightweight flywheel would be a great overall clutch.
Feel free to give us a shout, or email Jacob@monsterclutches.com if you have any questions.
Found the following review on CF, what is the owner referring to by hot balancing issues? I don't want to revisit the problems I had with non-GM clutches or receive grief from my clutch/tranny tech I've been using for 15 years about straying away from a proven solution. I don't want any band aids to get it to work like GM, including but not limited to using shims.
http://www.corvetteforum.com/forums/...t-in-here.html
Some vendors say it comes with just a 1 year warranty against defects, another vendor says it comes with a 2 year warranty which can be extended if you buy the rebuild kit. If I don't have to rebuild it for say 5 years, and then I rebuild it, do I get a new 2 year warranty, or does it need to be continuously under warranty to get the extension? How long will you support this warranty cycle?
McLeod RST & Street Twin also seem to be in the running for the ~$1200 price point including a lightweight flywheel.
https://ls1tech.com/forums/manual-tr...you-using.html
LT1-S: Must use their heavier flywheel. 9.5" clutch diameter vs 12" diameter that I have now. I read that it's 49.5lbs total, is that with the 18 or 28lb flywheel? What are the diameters of both flywheels? SNL states no shimming is needed, bolt on and go, that's a definite plus. Confusion on the warranty period and a rumored rebuild kit which extends that warranty. Rated to 700rwhp/700rwtq.
RST: You can buy their flywheels or re-use an existing flywheel, although SNL seems to advocate this as a weak point with the stock cast flywheel. 10" clutch diameter compared to 12" now. I've read about some people having install challenges a few years ago, have those issues been resolved and it's a complete bolt-on and go setup as well? McLeod seems to sell both steel & lightweight flywheels... unclear on the weight & diameters. I've read of some people only getting a couple of years out of this clutch. Rated to 800bhp.
How does the MOI compare between the LS7 w/ 13lb flywheel, the LT1S with the 18lb flywheel, and the RST with the 13lb flywheel? Would I experience any different behavior with the larger MC bore with these two clutches? The engagement window will remain the same? I'd rather not change MC's if it's not required.
What other factors do I need to consider?
"The RST/RXT pressure plate is designed with the factory hydraulics stroke of .440” in mind, thus requiring factory master & slave to be used for proper operation."
Looks like the RST is designed for the factory MC. I wonder if that means it has to be completely OEM, or just the OEM bore? Are the only side effects of using what I currently have be a narrower engagement window? It should be the same window as I'm accustomed to now, right?
Looks like the same thing for the LT1-S?
The guy above didn't like the narrow engagement window, but that has nothing to do with the clutch kit, correct? Only the hydraulics?
I'm seeing a few references to the ACT Twin but not any details. Should that be considered also?
BIG power handling is NOT a concern for me.
I already have an SFI LS1 FW, Brand new, zero miles. I fugged up and purchased an LS7 clutch (also brand new) but realized that these two items dont work together.
Anywho, my combination is the following:
1987 Chevy Pick up
T56 trans
Stock LS1 shortblock
Ported 317 heads
custom cam & valvetrain
Maggie SC (smallest pulley would could get)
295/50-15 rear tires w/4.10 gears
I plan to terrorize my neighborhood and cruise ins. Also hit the track every now and then. But mainly, a street truck that will get driven quite often, back in forth to work/home, date nights with the wife, (I added Vintage Air) run my girls up to the park, etc etc I dont want a heavy *** pedal!!
To be fair, I was looking at the ACT clutch (GM9-HDSS) as well, but I didnt see them as a Sponsor in here.
Looking forward to your response and Thank you for your time.
Craig
