04 GTO T56 issues! HELP!
Hello everyone,
I have a 2004 GTO T56. It has right under 100k miles. I have an oem replacement clutch kit in the car and MGW shifter. about 7500 miles on the clutch kit. Recently the gears have been harder to shift into and during racing the car the clutch pedal will stick down or not shift at all. Including reverse is hard to enter. It may take a couple trys. The trans fluid has been replaced with fluid from the dealer.
The car does have engine mods but the clutch doesn't slip. What could my issue be? A bad slave cylinder? Bad throwout bearing?
