Get a Tick MC or Replace the Slave?
I have no problem spending the coin for the Tick Master Cylinder, IF it will 100% fix my problem. But, I don't want to spend the money if it won't. I also would rather not pull the transmission to replace the slave cylinder, but if it would fix my problem, I would. So my dilemma is I need to know exactly what is wrong before spending time and/or money throwing parts at it.
The clutch pedal itself feels great. There is about 1 inch of free travel on the pedal at the top before it has pressure, and as I said it feels great, firm but not too firm and it ALWAYS returns, not once has it ever stuck to the floor. The master cylinder reservoir is always full, but no matter how many time's I've bled the thing and put in new fluid, it comes up black as ink in a matter of minutes. But, it doesn't seem to be leaking. Under the car, there is a small power steering leak and a valve cover gasket leak (new gaskets are on order), which makes it impossible to tell if any fluid is leaking out of the bellhousing from the slave.
So what should I do? Does this sound like something the Tick MC will solve, or do I need a new slave? Also, at WOT redline shifts, it will go into gear but grinds like a mother******, and it happens in all gears at WOT. The grind got better after the drill mod, but is still ever present.
