clutch chatter/vibration
i just installed my spec 3 and a stock resurfaced flywheel, i used the alignment tool and tightened the bolts down in a criss cross pattern. when the car is running and not moving i can spin the motor to about 1500-1700 rpm's when i begin to feel a vibration, as soon as the engine slows vibration stops, same happens when driving. i also just rebuilt my trans, it shifts great
what might be happening?
I had the same problem when i first got my spec 3 clutch...Although i had speed inc install my clutch and they had to put a whole new clutch and flywheel in...They said it was something within the clutch but i don't remember exactly what the problem was...
omg, I'm having that exact same problem. Mine does it at 1800 and one higher rpm I can't remember. Very noticeable though. They said to bring them my clutch and flywheel and they would balance it if that's what it was.
