Its time to upgrade the clutch!
Hey, guys, I am looking to upgrade my clutch on my 98 Camaro SS. Once I get the car tuned it will be running around 500-550 hp/tq. By the end of 2017, I want to be running 700 hp/tq so I need something future proofed. From my research, it seems like Mcleod and Monster are the best ways to go. I need a clutch with the least amount of noise and chatter. The car must still be comfortable to drive because I drive this through bay area traffic quite often. I think I will be going with a twin disc mainly for the comfort of driving. So here are my questions. Should I purchase Mcleod or Monster based on my criteria? Should I purchase a new slave cylinder even though I do not think there is anything wrong with mine? Is a light weight fly wheel worth it for a street car? the lighter flywheel is only 10 lbs lighter. Would that really make a big difference? Do I need a bleeder? Why are there different length bleeders? Since I am new to this do you guys recommend a speed bleeder for ease of install? Do I need a new master cylinder even though mine seems fine? What else needs to be swapped when upgrading the clutch? Thanks!
The McLeod RST twin has organic disc which will have smoother engagement. Per McLeod use stock hydraulics (not a larger bore MC)
The RXT has more aggressive ceramic disc which is more suited for the 1/4 mi use. You can still use it on the street but chatter can be a problem unless you find the ideal rpm clutch release technique.
Hi SS, our DYAD clutch seems like it would fit your ticket nicely. Its potential holding capacity is much higher than what you are shooting for, which means it will last you a long time, and will not need to be replaced if you get the itch to mod more later on.
We've also designed the DYAD in such a way that you do not sacrifice any driveability whatsoever. It's smooth engagement and light pedal pressure make it feel almost like a stock clutch!
So I can use the stock slave and master cylinder that is in the car already? I am pulling towards monster clutches mainly because of the price and I don't see much negative comments about them. Anyone who's tried DYAD want to give me some input on that clutch?
We know quite a few people here on the forum running on our DYAD, so hopefully they can chime in with their experience.
As far as a lightweight flywheel, if the car is going to be street driven or drag raced you want a heavier flywheel.
The you will not need a new master, unless your current one is leaking.
A bleeder makes life easier.
Give us a shout if you have any questions.
