Anybody have experience with a Spec Stg. V?
I was wondering if anybody here had any experience with the Spec Stage V Clutch. What is the pedal pressure like? Are you able to keep the chattering to a minimum? Any problems in the rain? Thanks a lot for your help!
I have the SPEC stage 5i
I did not get a chance to launch it hard yet. but I can tell you streetablity is INCREDIBLE. For about 300 miles I had NO chatter, and it was like stock. Pedal pressure is higher but nothing crazy. You could begin to engage the clutch off idel and roll into it like stock with no chatter. I had a RAM setup before that worked well and hooked for 1.44 sixty foots. It did chatter a bit. If this SPEC stage 5 holds at the track...i dont see how a clutch could be better.
So..for me the jury is still out.....but looks promising.
