a4 to m6 swap 02 z28
Basically you will need to wire the brake pedal switch and the clutch switch to the shifter switch, you will also need to wire the reverse lights to the shifter switch.
It sounds like a pain but you can find the wiring diagram and it will make more sense
https://www.google.com/search?q=a4+w...ch.com&imgrc=_
http://s1248.photobucket.com/user/lj...tml?sort=3&o=1
The only thing that keeps the swap from running, meaning the only thing that actually prevents the car from just being slap the parts on and drive, is the neutral switch. You could just connect the two wires and bypass the switch but I prefer to do it right.
