Tr6060 twin disk vibration
I installed my new monster lt1-s twin disk on my 13 camaro ss. Install went smooth torqued everything down the way it was supposed to. Went for a test drive and the shifter starts to vibrate pretty good then goes away as you continue to drive. It makes somewhat of a humming noise at idle and smells like clutch really bad. From what I read the noise and smell is normal during the break in period. My question is, is the shifter vibration normal and if it's not what could be some possibilities before I drop the trans again? Thanks for any help
Moderator
Received 1,836 Likes
On my old monster S3, I used too much ARP lube on the FW bolts and it slung grease all over the clutch. Took about 500 miles to burn off and it made it really chattery. I even called up monster about it and they said it happens all the time.
That was a single disc experience, but maybe that's all it is
I am in the process of breaking in a mcleod RXT. I noticed the shifter noise and vibration when below 2k rpm. No clutch smell at all. I am attributing the shifter vibration noise to the solid hubs in the clutch. I could be wrong though.
