Clunking sound?
stock u joints have to be heated with a torch to be removed.
unbolt the d.s and take it off the car add see if the ujoints are tight or if they have some slack in them. then turn the rear where the d.s bolts to it and see if there is excessive play in the gears.
if its bad, just keep sticky tires off of it and dont do big cluth dumps. its probably not bad though or you would notice it alot worse if that is what it is.might be in the trans, just eliminate easiest things first.
www.thunderracing.com
it made a big dif, its not necessarly a comfort mod, but it made it feel a lot tougher.
umm fix that mount, im sure all the noise is probably coming from that.
sorry guys....i'll get right on it next paycheck. Are they hard to replace?? Never did any tranny work before. I knew i shoulda told you about that from the start, figured if i heard the noise in the rear what would the tranny which is closer up front have to do w/ it....sorry...
http://www.installuniversity.com/
its easy, support the trans with a jack, unbolt 4 crossmember bolts, center transmount bolt, drop crossmember, unbolt 2 13mm bolts holding mount, remove mount, install new mount, put crossmember back on, torque everything down.
