need help to find a clutch assem 25-30lbs
What I found so far is all the twins with alum flywheel are 33-38lbs except carbon high end stuff.
I want a clutch between 25-30lbs and the best I found so far is a mini twin spec 19.5lbs.
There are the qtr master that sounds nice but its very hard to get info on the specs/weight/price and whats available and dont know if they have full kits.
Car is a 3650lbs 5th gen cam& boltons. I want the most outta it. I know its gonna suck for driving and launching at the strip but its more a roll racing car. It does have drag wheels set.
Open to any suggestion at a reasonnable price. The mini twin is at 1484$.
Moderator
Received 1,838 Likes
Mamo one is right at 30. Can get with AL flywheel
mcleod mag force twin if i remember right is 26 lbs, mantic has some light ones. Of course rps billet twin. No experience with any. I would personally like to try the mag force with the iron discs and pin drive. Also want to try the rps twin billet with the aluminum flywheel.
Where the weight is, is as important as overall weight. And do you even need a multiplate clutch ? What sort of power/torque ?
