how far is everyone pushing there t56 ?
I know this is a bit random but wondering how far /hard you guys are pishing your t56's
I have a older d&d built 98-02 fbody spec t56 in my nova, I believe it was rated at 700ftlbs , but it still has the 28spline output shaft.
the car has a 365" ls3 head s475 turbo currently at 12psi. I'm guessing its currently around 650+ rwhp range . so far it's been good but haven't had it o. sticky tires either yet. im caging the car this winter and would like to turn it up. wondering what the trans can take before it goes pow!.?
I'm guessing a rpm,tick, d&d etc modified magnum will be in my future
when this one gives up.
With the wrong clutch setup, 500-600 ftlbs.
With the right clutch setup, 800-900 ftlbs.
Either buy the bare minimum amount of clutch that can hold your planned power, or buy more clutch than you need and use something external to soften it's hit.
Grant
Grant
Some break them at sub 500...others are surviving beyond 1k.
There is no simple answer. Driver, usage, environment, power and box condition etc....too many variables.
But most do seem to live well beyond the factory rating of around 450lbft
A broken transmission is also of little use.
Too much clutch not only kills transmissions, but it also kills et. 9.85 @ 144.75 with a 1.55 60', 20th on the fastest 6spd list when ranked by speed, but only 29th on the list when ranked by et. If road course is your focus, carry on. If you are looking for drag strip performance, you are leaving a lot on the table.
Manual guys tend to buy a clutch based on what they may need sometime in the future, not realizing that it will cost them current potential and possibly hurt their transmission.
Automatic guys tend to focus on matching the converter to their current combination, then change converters as they outgrow them.
weedburner knows what's up.
Same with the honda scene, people running stock boxes at 500-600hp on k24s. Soft clutches reduce driveline shock and prolong the life.
My clutch was matched exactly to my LS3 and setup for now for this reason, multi discipline car really. If I dump a 450ci+ NA donk in it one day, I'll get a new clutch. They're not that expensive if you can afford to upgrade the rest of the stuff. Stock t56mag will do fine until things get crazy, they are 700ft/lbs off the shelf.
But that time was done on basically a stock T56, albeit with Viper mainshaft, and the very same box served me well until this year when 5th gear workings failed on me.
If I was building a drag car only...clearly it would be automatic.
This really makes me rethink my monster clutch, stage 3. It's not installed yet, been sitting in my garage for two years now. I want to be able to drive my car like I stole it, it rarely comes out and when it does......
That clutch and the drag radials on opposite ends are probably going to try and find a weak link in between them sooner rather than later.
Any feedback on the clutch tamer with this particular clutch? Sorry for the thread jack.
yes.....car is set up as pro tour .....which to means do it all. it will go to the drags on 325/50/15 drag radials a few times a year, rest of the time its on the street o. 315/30/18. . this year I was finishing and tuning it and I still managed almost 1000 miles on it. car defiantly has power to go deep into 9's just matter if I can get it to leave......hence the cage this winter.
