F body MGW shifter issues
With my center console installed, the shifter is hitting the console. Won't allow the car to go into 5th, 6th, and reverse. Haven't found any other issues like this on here so I thought I'd post. The car does have Spohn solid motor mounts and poly transmission and torque arm mounts.
It is an issue with the Spohn solid mounts. I had the same issue once mine were installed, never had the problem with stock mounts. I trimmed the console a bit and didn't have any issue afterwards.
