What clutch & flywheel for a 500 hp turbo car?
I am doing a 6.0/t56 swap into my 69 camaro with a single bw73 mm turbo. I “ hope ” to make 500 hp on 93 octane and it will be a street car. I may run some et streets but never any slicks and won’t ever do any 6k launches from a dig.
So one question I have is, does a heavier flywheel really matter on a turbo car?
Or does that lighter flywheel really make a big difference?
Then what clutch to buy?
Also will the stock gm hydraulics, from a 4th gen, work with this clutch you recommemd?
You want a twin organic disc clutch. McLeod RST. Uses stock hydraulics. Don't do a lightweight FW on a street or drag car.
Monster makes a twin also. I don't have any experience with it
I have the McLeod
I have the McLeod
The lighter you go the more aggressive the clutch will feel on engagement.
All of our units work with stock, or aftermarket hydraulics.
