Help with Tremic trans
Old Mar 4, 2018 | 07:06 PM
drgracen's Avatar
Default Help with Tremic trans
Just looking for some input from others on what you'd recommend for a trans. I'm an automatic guy not very knowledgeable on manuals. Have a 69 camaro with munch in it right now, but just as I did in the rear I want to pull the factory stuff out sit it on the shelf so I don't kill it. Pulling the 396 and puting a 540 in it. Any recommendations on transmissions to throw in it. I've been told Tremic but see several different models. Any help greatly appreciated !!!!
Old Mar 4, 2018 | 10:47 PM
gnx7's Avatar
If you want any chance of it living with abuse.... plunk down and get the Tremec T56 Magnum. A TKO600 5spd won't last behind that setup. 2.66 ratio is the best option (TUET11009)
Luckily in the Gen1 Camaros you don't need to modify the trans tunnel.
Quicktime SBC/BBC bellhousing will adapt it. Then you just order up a twin disc clutch/flyhweel for the type of driving/abuse you plan to give it
Old Mar 5, 2018 | 05:58 AM
drgracen's Avatar
Appreciate the reply gnx. I'm on a mission looking for a 56 now. Definitely want something strong. Have a procharger setup for the 540 I most likely will be messing with.
Old Mar 5, 2018 | 11:57 AM
BALLSS's Avatar
OP
I bought my T56 from D&D performance in Michigan. They are one source that should be able to answer your application ?'s
I agree the magnum, as suggested, would be good
Old Mar 5, 2018 | 12:25 PM
drgracen's Avatar
Thanks ******. . I'll give them a call. Just about ready for the transmission. Engine should be ready to fly few weeks
