T56 rear facing turbo crossover pipe
I had a company flake on my project after making me wait 6 months for a front facing dump & crossover so my question is if I go with trick,kb racing or dirty dingo all of these kits have rear dumps and crossovers will my t56 and clutch be okay with the excesive heat from the Crossover?
I really appeciate your time and replies guys
What car are we talking about here? Holley makes a cast iron log turbo system with dedicated crossover tubes for various transmission options. Heat from the crossover should not be an issue because it is constantly being cooled by moving air under the car. If you're paranoid, wrap the crossover pipe.
Andrew
Andrew
Some aftermarket companies are making it tough to trust, however if most of the kits you see do it then it's likely okay. Unless the others are just fine China companies that copied the other. Then also go with the other guys idea and wrap the crossover if it looks to close.
