TUET11012 on 99 f-body
Hi folks, just bought a 99 SS. Car has sat for a couple years because previous owner had a t56 magnum TUET11012 installed poorly. I have the paperwork in hand. So they hacked up the console as expected. Shortened drive shaft poorly. Torque arm mounted on cross member ok.
had a new driveshaft made yesterday as I didn't trust the old one and it was a steel piece.
anyways. Looks like rev is plugged properly 'wire's
but no Speedo. What do i need to make this work.
all past info is over 5 years old. Looking for a plug and play option.
The Magnum comes with a different tail housing from the factory. I only know this because that was one of the parts that D&D changed on mine as part of making it a drop in for my car.
Call Don at D&D and he can probably tell you what you can do to make things work.
