LQ9 to ZF 6 Speed?
LQ9 to ZF 6 Speed?
Does anyone know if they make pairing kits to mate a 6.0 LQ9 to a ZF S6-40 trans? I'm fairly certain the LQ9 is based off the LS2 but I don't know to what extent. Will a bell housing clutch and flywheel for an LS2 or other LS work with an LQ9 or is modification required? Thanks in advance
Wasn’t the ZF a C4 transmission - which is NOT an LS car? I’m sure this is going to be no different than trying to convert any other LT1 trans. Maybe more difficult since the ZF didn’t come behind any LS as far as I know of.
What does that have to do with a ZF? The ZF is a German transmission with no aftermarket support whatsoever, they don't even sell rebuild kits for the thing, it was only put in like 3 cars - all of them from different manufacturers with completely different setups - and here you are comparing it to a Muncie that was practically the T56 of its day. But by all means, have at it, let us know how you make out.
