Clutch line removal with a problem...
This one is free and easy
https://postimages.org/
Clutch line picture
This is the correct sleeve you press inwards to release the quick disconnect.
http://monsterclutches.com/1998-2002...aulic-retainer
The sleeve would be fitting to the female socket, which is a part of the (stock) slave, so it's going to be a standard thing. Even for an aftermarket Master, that sleeve is going to need to release the fingers on a stock slave.
What if you take new sleeves and cut them smaller with a dremmel tool? Could you then stack multiple shorter sleeves in there and keep shoving them in?
If you do the chopping method for the clips, I'd suggest putting a few pieces of high grade dental floss around each piece that you stuff in there. If, for some reason, you need to pull the cut piece out - maybe you can use the floss as a puller to get it out. (Maybe that won't work, but you may not have much to loose.)
