what is the best shifter?
Regardless, it was a HUGE step above the factory Hurst...the throw is shorter, and the gear changes are much crisper. You won't be disappointed whichever way you go...
Pro 5.0 will be notchy but you can really feel the shifting.
B&M is one peice, very sturdy, bit smoother than the Pro 5.0, shortening it isn't as conveinent
Hurst Billet Plus, decent short throw, not as notchy as the pro 5.0, not as smooth as the B&M...probably the cheapest (lss compatible).
Stock Hurst with short stick, not as much tranny noise, shorter throw, many people like this cause it firms up the shifts just a little bit but doesnt make it uncomfortable for every day use.
THis is just what i've researched, I have only personal experience with the stock hurst with lous short stick, which felt pretty good.
Got a great deal on mine for 164.99 shipped from Tom at LS1speed.com. Should get it by monday or so so once I get it and install it ill let you know what i think.
