Bit the bullet and ordred a Mc Leod twin disk
Spec was starting to slip bad along with the stock T56 something had to be done. I hear I will love this clutch? Street manners and track bashing! I have a built T56 coming, and the new clutch set up. I am psyched. Any opinions or real life stories are welcome. This was not a cheap purchase. Angelo
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Ill be honest...Its like no clutch I have ever used before. Though it is a beast. I can do a 6000 RPM clutch dump and it grabs hold, But it doesnt like to be sliped. They are REAL expensive,like 1500 bucks with the flywheel. It can take some abuse, thats for sure.
Originally Posted by tump
Ill be honest...Its like no clutch I have ever used before. Though it is a beast. I can do a 6000 RPM clutch pump and it grabs hold, But it doesnt like to be sliped. They are REAL expensive,like 1500 bucks with the flywheel. It can take some abuse, thats for sure.
I love mine. It is very grabby. Takes some getting used to. I know the Spec is pretty popular here from what I've read, but I don't see how there can be something better than the McLoed Dual. I don't have a problem slipping mine ever so slightly when going over speed bumps, or when in traffic or rolling up a slight incline. It's close to perfect.
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by SSCamaro99_3
I really like mine. The 10-bolt is crying for mercy. From what I understand it is much better off to dump a Twin Disk instead of slipping it.
you are correct! you
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
my .02 CALL AND SPEAK with Les! @ McLeod, i don't mean to soundsmug, but i will tell you he gave me a quick list of do's and don't with that clutch for it to last!
enjoy IT!!!
