Bleeding Spec 3.
Old Jul 10, 2004 | 10:48 AM
1fstGM's Avatar
Restricted User
Default Bleeding Spec 3.
I just changed my slave cylinder and now that the tranny is back up the clutch will not come up by itself. The spec 3 was working fine with the set up before I changed the slave cylinder. I bleed the clutch and it still doesn;t pop back up. Any suggestions?
Old Jul 10, 2004 | 12:41 PM
SoloSport's Avatar
Sup, it's K.O.
Um...I can only think that you should take everything out, put in a new master cylinder, the new slave, bleed it (at least 3 times)...make sure the clutch/throw out bearings/etc, are all in place cause something could be getting caught on something...oh yeah...I got a Spec 3 too...but I didn't install it, GM did...um...I've never heard a problem like this...I'll ask around though
Old Jul 10, 2004 | 01:31 PM
1fstGM's Avatar
Restricted User
Alright, thanks.
