Should T56 QD hard line be loose?
Like the title says, should the QD hard line be loose where it's pinned to the slave/TOB? I assembled my trans and clutch and bolted it to the engine. I didn't notice if the line wiggled a little before I mated the trans to engine, but now that it is I see it will move a little bit. I really don't want to have to pull everything back apart, but I will if necessary. The slave/TOB is a standard GM replacement setup (non-aftermarket).
