Shift issues after LS7 Clutch/PP/Flywheel install
Sounds like the slave is not doing its job.
I'm not sure how to see if it's pushing it out "enough". I feel like if it weren't pushing it out enough, shouldn't it be grinding or not engaging in ANY gear? Is there a difference in the amount of release required per gear? Right now it goes in 1st, 2nd, 3rd, and 4th with minor resistance (more than I'd like, though). 5th is difficult, 6th is difficult, and reverse grinds. Is there more fluid required to push the slave for the higher gears/reverse? I don't think there is, but now I'm starting to question everything I thought I knew. Right now, the torque arm and driveshaft are out. Sometime this week I'll drop the transmission and see if anything sticks out at me.
