2005 C6 T56 in 01 C5 Z51
Old 03-06-2019 | 12:41 PM
C5SixSpeedZ51's Avatar
Default 2005 C6 T56 in 01 C5 Z51
My 2001 C5 Corvettes T56 is broken and Ive found a T56 and Torque Tube out of a 2005 C6 Z51 for 875.00
will it bolt in with No Modifications, plug and play???
I need to know before I drive 2.5 hours to go get it.
Old 03-07-2019 | 12:17 PM
voda1's Avatar
The C6 torque tube is too long as well as the shifter is in a different position.
IIR the trans has a 30 spline output shaft as opposed to the 27 spline C5.
Old 03-07-2019 | 12:51 PM
2005 is the only year T56 that will interchange. I bought a 05 Z51 Transmission Yesterday. They do have 27 spline also.
Old 03-08-2019 | 10:14 AM
voda1's Avatar
Does the C6 tailshaft housing need to be swapped for the C5 one?
Yes, the bolt pattern is different between the C5 and C6 differentials.
Old 03-08-2019 | 10:40 AM
I'm still trying to find out what all works and what doesn't. I have a Torque Tube,Bell housing,and T56 transmission out of a 05 I plan to put in my 2001 if it will all work.
