Ticks master cylinder issue
Im currently doing a LS1/T-56 swap into my 79 firebird. I decided to install a ticks master cylinder. After about 10 failed attempts of bleeding it successfully i decided to try different methods, putting the traditional method to the side. I bought a mityvac and tried that. Still no luck, the vac just kept pulling air and never stopped even after 2 full hours of bleeding. i decided to unhook the master cylinder from trans and entire car. then used the mity vac to check the master cylinder. It seems to be pulling air in somewhere by the plastic cap on top of it. You can see air bubbles when vaccing it and it wont hold suction when end is plugged and the other is being vacced. It was a brand new master cylinder and i did nothing to damage it. Just wondering if tick will replace it for me and stand by their product. Hoping to atleast hear from an admin. THANKS
