(Base 08 c6) ACT Twin Disk won’t engage gears with engine running
If the car is off it will go into all the gears, if I turn the motor on it won’t. Does it seem it’s the pressure plate? Or something different. New motor was just swapped in. Any ideas?
I had some issues with the Miata after the engine was out one time. I re-bled the clutch and increased the clutch pedal travel a bit and it was fine.
