Tick help
Is this the Tick Performance adjustable clutch master? If so, I believe you just turn the rod to lower or raise it until you get it where its needed.
I had the same problem. It took me a good 30 min. to finally get it. I just kept fiddling with it and it finally popped on. It has to be just right/flush to get it to pop on.
