Such a thing as too many adapters?
I have an LQ4 and T56 installed in my E46 BMW and have a question about the slave cylinder hydros. I have a Tick remote bleeder and the factory style quick disconnect. The clutch line I have that runs from the master to the slave is a 3AN line but was designed to replace the factory QD altogether (I didn't realize this when I bought it). Also, I can't find any QD to 3AN adapters, only 4AN. If I use that, I can use a 4AN female to 3AN male reducer and all is good, EXCEPT I run out of room in the tunnel. So, is there any issue using a QD to 4AN adapter, then a 4AN 90 degree fitting, then the 4AN to 3AN reducer, and connecting my line to that? I very much do not want to have to drop the trans out to change out lines at the slave cylinder.
