Weird clutch issue
set up is a LS 6.0 with a t56. Stock LS1 style slave with a tilton 3/4 adjustable master cylinder. Monster stage 2 clutch.
the clutch and trans shift fine no issues with those. The clutch is shimmed perfectly and is within spec using the tick shims.
the issue I am having is when I push in the clutch then immediately put the transmission into 1st or any gear the car moves ever so slightly. Happens in all the gears.
But if I keep my foot on the clutch to the floor it will move into all the other gears without moving the car. And if I go, push in the clutch, wait about 3-4 seconds then put it into gear, the car will not move at all.
This was happening when I had an LS7 clutch and with my monster stage 2 clutch. So I am think it is possibly the slave cylinder? I have been bleeding the system but nothing as really made a difference.
Also I have a speed bleeder and a mity vac for the bleeding. Any help is welcomed. Thank you.
Get the McLeod MC (made by Wilwood) if you find the MC is the issue (likely)
But I did notice a small amount of fluid on the pressure side line of the slave, this tells me that the fitting inside of the bell housing has a small leak. Do you guys think that that could be causing the issue?
