Tick master Adjustment / bleed procedure
Clutch is slipping very bad, smoking , whining, weak grab, pedal feels a bit awkward. Ordered a LS7 to replace it.
I've been a lot happier with the cars I've driven with a Mcloed and a stock master
As to your master, I still run the tick master setup, but I went from the 7/8" bore tilton master they originally supplied back down to the .700" bore master, which eliminated some of the light switch feel of the clutch - more pedal travel to move the pressure plate fingers the same distance.so I could feather it better.
My Monster S3 lasted 11k miles with the 7/8 bore tick master, before I put the RPS clutch in it. I pulled the MS3 out mainly due to weight. After putting the rps in, I went to the smaller master. Actually, that was after I drove the car to Tony's batcave and we beat the **** out of it. It was one of his recommendations to try a smaller master, so I did. Basically, the smaller master with the rps feels very much stock like.
I guess that's a long way around of saying you're not wrong to think to try a smaller master cylinder, but maybe the answer is to consider swapping out to a different tilton. Also, highly recommend looking into the tilton 6000 series HRB vs stock HRB. tremendous difference in pedal consistency.
Quick question, if placing the quick bleeder into brake fluid wouldn't using a different container (small bottle) work as good or better than placing in the master's reservoir? I wonder if this could help to prevent the risk of getting too low in reservoir fluid so fluid levels stay consistent and would this help if the bottle were higher or lower than the reservoir?
On my Tick/Monster combo, sometimes the clutch pedal is hard to push, other times its super light. It has always been like this.
Anyone else experience something similar?
