TR6060 on Gen V 6.2 LT1/LT4?
Hi,
as far as i know the TR6060 from the 5th Gen Camaro bolts up to the Gen V 6.2 LT1/LT4 engine.
Only the top hole of the bellhousing cant be used due to the HPFP of the LT1/LT4.
Can I use the stock LT1/LT4 clutch with the TR6060?
Is the stock TR6060 clutch slave cylinder compatible with the LT1/LT4 clutch?
Is there anything else that needs attention to make it work?
I read that I might need a different pilot bearing? (AC Delco 33-11546)
